Openreach or plus net at fault?
- My Order
- Openreach or plus net at fault?
a week ago
Re: Openreach or plus net at fault?
a week ago
What is the claimed problem? If you had a working connection whilst with BT, I cannot quite understand how you have a problem now. If you are merely switching who you pay, the service comes down the same wires.
a week ago
View my job / eco/SI/VMJ checked for updates? 05/01/2021 � 13:24 -
Notes: InCompleteReason:Dis one leg between house and cab. Up from cab 210m. from the house 400ish. ,, Dispatch Comments:ART1256MASK narrowband incomplete, Start faulting at PCP. DIS 1 LEG IN NETWORK., TRC Questions: ,Eng UIN:608447849UpstreamSpeed:,DownstreamSpeed:,Tested:1,NotTestedReason:,DemoPerson
a week ago - last edited a week ago
So were you having problems whildt with BT? I'm not a telecoms engineer, but that appears to be a problem between your house and the local cab, which would not just become apparent at a change of supplier, it would have been there whoever you were with.
The 'report' is as useless as a chocolate teapot, tbh.
Did neither engineer discuss the result of their investigation with you?
a week ago
a week ago
It should be a straightforward switch, yes, and as the only change, which you would not be aware of unless you checked, would be a routing change on the internet network, this sounds funny to me.
As I asked, did you have any conversation with either of the engineers after their investigations?
a week ago
a week ago
Only the plusnet engineer
all the Engineers are Openreach
a week ago
a week ago
a week ago
If there is further BTOR work needed, based on that 'report' you provided, then no supplier, other than Virgin, on their own network, will be able to supply you with a service until it is completed.
a week ago
a week ago
Good luck in getting PN to pay for that - the problem appears to be in the BTOR realm.
- My Order
