Openreach or plus net at fault?
ChrisT1
Hi I'm wondering if anyone can assist me I just switched from bt which I'm now regretting as I had perfectly working broadband to plusnet. I was given an activation date of the 5th jan. Along comes the 5th no broadband chased up with customer services who eventually found a note saying required openreach engineer visit. Engineer has been today 11th Jan still hasn't fixed it and now back in limbo with no broadband which is needed more than ever now for home school and wife working from home. Who do I go to for compensation when this is sorted and would I still have this problem if I cancelled with plus net and went with another provider?
12 REPLIES 12
Legend
Fixes: 255
Re: Openreach or plus net at fault?
What is the claimed problem? If you had a working connection whilst with BT, I cannot quite understand how you have a problem now. If you are merely switching who you pay, the service comes down the same wires.
ChrisT1
I was thinking the same the first engineer left this note on my ticket
View my job / eco/SI/VMJ checked for updates? 05/01/2021 � 13:24 -
Notes: InCompleteReason:Dis one leg between house and cab. Up from cab 210m. from the house 400ish. ,, Dispatch Comments:ART1256MASK narrowband incomplete, Start faulting at PCP. DIS 1 LEG IN NETWORK., TRC Questions: ,Eng UIN:608447849UpstreamSpeed:,DownstreamSpeed:,Tested:1,NotTestedReason:,DemoPerson
Legend
Fixes: 255
So were you having problems whildt with BT? I'm not a telecoms engineer, but that appears to be a problem between your house and the local cab, which would not just become apparent at a change of supplier, it would have been there whoever you were with.
The 'report' is as useless as a chocolate teapot, tbh.
Did neither engineer discuss the result of their investigation with you?
ChrisT1
No problems with bt at all only issues since the switch presumed would be a straight forward switch
Legend
Fixes: 255
It should be a straightforward switch, yes, and as the only change, which you would not be aware of unless you checked, would be a routing change on the internet network, this sounds funny to me.
As I asked, did you have any conversation with either of the engineers after their investigations?
ChrisT1
Only the plusnet engineer who was really unhelpful just said nothing he could do and drove off the one today must of just worked at the cabinet and left
Fixes: 395
all the Engineers are Openreach
Legend
Fixes: 255
Thanks, @MisterW  - I typed that, plus a bit more then hit the wrong button.Sad
@ChrisT1 The only suggestion I can make is that you contact PN and ask them to chase this with BTOR. In my experience, the engineers will tell you something, even if it is not entirely true, if you ask them.
ChrisT1
Cheers spoke to plus net said are chasing it with open reach who claim further work is needed but no real explanation will going to a different provider still cause a problem I urgently need broadband for my daughters home learning more than anything she is gonna end up behind everything is online.
Legend
Fixes: 255
If there is further BTOR work needed, based on that 'report' you provided, then no supplier, other than Virgin, on their own network, will be able to supply you with a service until it is completed.
ChrisT1
Guess I'll just have to pay for extra mobile data and pass the bill to plusnet for it thanks for the help anyway
Legend
Fixes: 255
Good luck in getting PN to pay for that - the problem appears to be in the BTOR realm.
