Openreach fibre appointment - need to change date
wivenhoe6
It looks like I may need to change the date of my Openreach appointment. Please could a member from the Plusnet team send me a PM with the earliest appointment slots available & I will confirm.
Thanks very much.
9 REPLIES 9
Fixes: 334
Re: Openreach fibre appointment - need to change date
It would probably be easier and quicker to call in, @wivenhoe6
wivenhoe6
@jab1
Thanks John, I gave them a call earlier today & the Plusnet rep advised that the Openreach appointment can't be changed until the engineer has made their initial visit/assessment.
Fixes: 334
Ah - I can't remember  what went off in your initial post, but is this a KCI2 Assured installation? If not, I don't quite understand the agents comments. In any case, as you will possibly need to be available for the 'initial assessment' they should be able to change things.
I'll tag @MisterW  on this as he has greater knowledge.
Fixes: 86
@wivenhoe6
Are you talking about FTTC (Fibre) or FTTP (Full Fibre).
If the latter try the following
You need to see WBC FTTP in the left hand column. If it shows, what does it say to the right?
There should also be a narrative below the results window which will state if any install problems are expected.
wivenhoe6
@jab1 Thanks, I just googled KCI2 Assured installation & found a previous post by @MisterW . According to https://www.broadbandchecker.btwholesale.com/#/ADSL/AddressHome  it's a KCI2-Assure installation. Thank you, you've helped me get a better understanding of what the rep was trying to explain to me.  Smiley
wivenhoe6
@bmc Our posts crossed but I think I've answered your second question. It's a full fibre installation.
Fixes: 334
No problem - that's what us unpaid staff are for. 🤣
wivenhoe6
And it's very much appreciated!
Fixes: 86
@wivenhoe6
Happy to help.
When installing the backbone network the engineers log any potential problems they may see with regard to actual property connections. For example with overhead this could be access or line of sight problems. Underground could be blocked duct or no duct at all.
It's not a problem until the property orders FTTP when, as you've discovered, a survey is done to see what's needed. If you're about when this happens you get a chance to discuss the location of the ONT with them.
