Openreach database
Westienono
Openreach database
Hi, I hope this is the place to get help. I tried to sign up with a new broadband provider but my postcode does not match the one held on the openreach database. Openreach are using an historic postcode. This was suoereceded by a change made to my postcode by the local council some years ago. My correct postcode appears on all address checkers and Royal Mail. I understand I need to get my current provider, Plusnet, to raise an ORDI to update the database. Is this correct and if so how do I get the process started.  Many thanks .
1 REPLY 1
Fixes: 1,474
Re: Openreach database
Moderators Note
This topic has been moved from ADSL Broadband to My Order
