Not able to log in
DavidW3
Not able to log in
I have recently signed up and i am not able to log in using the details i provided at sign up. Is there usually a delay in getting my online account active?
Thank you
8 REPLIES 8
TheMightyAJ
Fixes: 126
Re: Not able to log in
Hey @DavidW3,
I'm sorry to hear that. Is this in regards to a Home Phone & Broadband account or a Mobile account?
 Alex H
DavidW3
Thanks AJ. It is Broadband and phone line
TheMightyAJ
Fixes: 126
Thanks for confirming that @DavidW3. You should be able to access the Member Centre once the account's been created - are you getting any specific error messages when you attempt to enter your details?
 Alex H
DavidW3
It is saying that the username or password is not correct. I know they are correct so maybe it’s just too early to be set up. I have a date for line install
TheMightyAJ
Fixes: 126
Is it possible you'd accidentally entered a typo when creating the account password? It's been a couple of days since the account came online so you should be able to login by now. It might be worth resetting the password if this issue persists and if that doesn't work, give us another shout so we can take a further look into this with you Smiley
 Alex H
Alex
Fixes: 13
As AlexH says (good name, that's my name too!) I would try a password reset. I am guessing it may require you to click on a link from a non-PlusNet e-mail account or something on your mobile. They have to be careful of course to know the reset is legitimate and has been requested by the account holder.
Yes passwords should be active immediately, so as it not working for you then it doesn't sound right.
DavidW3
Thank you for your help. I reset the password and it works. Very much appreciate how quick you got back to me
TheMightyAJ
Fixes: 126
No worries @DavidW3, I'm glad to see that's done the trick Smiley
 Alex H
