No service provided after switching
- My Order
- Re: No service provided after switching
03-08-2022 9:04 AM
03-08-2022 9:27 AM
Moderators Note
This topic has been moved from Full Fibre to My Order
05-08-2022 11:35 AM
Hello @bosco1972,
I'm sorry for the delay in getting you connected, I can see the hassle this has caused and I am sorry for the frustrations this has caused.
I can see the order has now been completed and there is an active connection, can you confirm this is correct on your side?
Once this is confirmed I will be happy to look at a gesture of goodwill for the stress this has caused.
19-08-2022 9:51 AM
19-08-2022 9:58 AM
19-08-2022 10:06 AM
Have you reported a fault or tried any of the troubleshooting steps in the Help pages?
No ISP will let you switch providers on your whim!
19-08-2022 10:29 AM
19-08-2022 10:33 AM
19-08-2022 10:58 AM
Hi @bosco1972,
I'm very sorry to hear that there are further issues with your broadband since it's gone live. I've had a look over the case today and upon testing the line, we're not locating any specific underlying fault conditions. You'd mentioned the speed was coming in at 4Mbps - is the router setup within the Master Phone Socket or is it in an Extension Phone Socket?
Regarding compensation, I would be more than happy to discuss with you what we can offer as a gesture of goodwill once all the problems have been resolved, however it is important to note that, as you have brought it up, we wouldn't be able to fully compensate any loss of earnings during this period. With that having been said, we will consider the case in it's entirety and make sure to offer what we feel is a fair and proportionate amount.
19-08-2022 11:00 AM
Did you ever get back to them re the compensation?
yes it may look good on here, but you are not helping yourself. All your comments have been negative, but no details provides.
For example,
what speed service do you have?
what are the speed estimates for your line? Post the results of the BTW DSL Checker.
Post the results of the Help desk tab from your router
Is the line quiet? Dial 17070 option 2.
Have you had Openreach out to investigate?
Using the forum you can then use it as evidence to help you get results, and if the worse comes, as evidence to support your claim.
19-08-2022 11:46 AM
19-08-2022 12:01 PM
I get the negative comments, just trying to help you, by posting the info mentioned will help identify the issue.
Can you post the info I mentioned?
Not sure how Openreach can charge you anything, your contract is with PN. Or have you asked them to move the master socket?
From what you have said, it appears the router is getting good speeds, so how are you testing speeds
How are you responding to messages from PN, are you using the tickets in the member centre?
You say zero support, yet some things at least seem to be getting done - so lets take advantage of the forum and another staff member getting involved.
19-08-2022 1:05 PM
@bosco1972 - from what I can establish, your hub has been connected at a consistent rate of approx 43mbps since the service was activated. It would be useful, like others have said, if you can share the information displayed by your router at http://192.168.1.254, after navigating to Advanced Settings > Technical Log. You will need to enter the admin password for your hub and it might be an idea to obscure your username.
I'm not sure where the £150 engineer charge is coming from as I can see no evidence of this. If you can provide more detail then I'm sure one of the guys will be able to look into it.
@bosco1972 wrote:
Estimated speed should be around 40mb I'm getting 4mb.
Apologies if this comes across as condescending, but can I confirm that you're seeing 4mb/s (megabits) and not 4MB/s (megabytes)? The distinction is important as 4MB/s = 32mb/s, which isn't far off your estimate (albeit a little low).
20-08-2022 11:11 AM
20-08-2022 12:42 PM
Yet no answers to the questions.
- My Order
