No information on fibre upgrade
JayTee
Hi
We've been with Force9/Plusnet since 2004, and with our area now fibre we decided to upgrade our broadband.
Initially I tried via the website, but each time the upgrade process failed with no explanation. Finally managed to upgrade via a phone call, and was told our activation date was going to be 18th October paying the increase from the following billing date (which is 2 days away).
I've heard nothing since, no update on the question raised on my account, and no sign of the new router. How can I find out what's going on?
6 REPLIES 6
JayTee
Re: No information on fibre upgrade
Well the router turned up this morning, but still don't know if the fibe is enabled. Guess I'll try when I get home this afternoon
Fixes: 1,547
Hi there.
Sorry about the lack of communication with regards to your fibre order.
it's due to happen on the 26th. You'll receive an automated email in the early hours of the morning to advise your product change to complete but I'd expect the work to be completed during normal business hours.
So by the evening you should be on fibre. Smiley
JayTee
Thank you for the update
Fixes: 1,547
No problems. How's your new fibre service?
JayTee
Working fine, did a speed check after it switched & got 37.5
A lot better than it used to be Smiley
Fixes: 1,547
Awesomeness. Smiley
