No Internet on Activation date
jenkib
Hi, today is our activation date and we have no service.
We switched from Vodafone full fibre to Plusnet full fibre. We have an openreach ONT.
Is there a downtime between switching networks? Or has there been an issue with the switchover?
7 REPLIES 7
Fixes: 388
Re: No Internet on Activation date
@jenkib What lights (and colours) do you have on the ONT and the Plusnet Hub2?
Fixes: 251
Is it a one port ONT or a multi-port ONT?
There have been cases with multi-port ONTs where the new service has been provided on one of the other ports.
jenkib
It's a single port ONT
jenkib
Hub 2 is solid orange, the ONT has PON and LAN as solid green, LOS is not lit up.
Fixes: 388
You've provably tried this, but rebooting the router is always a useful exercise.
Fixes: 585
and assuming you haven't manually changed the username in the Hub 2, does it show the username as [email protected] or <youraccountname>@plusdsl.net
MatthewWheeler
Fixes: 503
Sorry to hear this @jenkib
It looks like your router is trying to connect with an incorrect password most likely due to you changing the password after the router was dispatched.
I've done some work on my end which should have sorted this. Can you do a full factory reset using the pinhole on the back and that should get you online.
As of the 1st of January 2026, I no longer work in Plusne,t so I'll be unable to assist you with any queries.
