No DSL signal being received
- My Order
- Re: No DSL signal being received
21-09-2018 6:52 AM - edited 21-09-2018 10:14 AM
Mark
21-09-2018 10:13 AM
21-09-2018 3:56 PM
Hi @Marksfish,
I'm glad to hear everything is up and running now. Please let us know if you have any further queries or issues and we'll be happy to take a further look into the issue.
21-09-2018 6:16 PM
So my sync is the highest it has been for a while, 55meg and throughput has increased during the day, at about 2pm it was only 20meg.
I have managed to set up my Thinkbroadband BQM by putting my webcam into the DMZ. Looks like everything is quite saturated around here.
Am I on a congested gateway?
Tracing route to marksfish.me.uk [92.48.108.230]
over a maximum of 30 hops:
1 * * * Request timed out.
2 * * * Request timed out.
3 * * * Request timed out.
4 17 ms 17 ms 17 ms be3-3104.psb-ir01.plus.net [195.166.143.136]
5 17 ms 17 ms 18 ms core1-BE1.southbank.ukcore.bt.net [195.99.125.130]
6 16 ms 24 ms 17 ms peer8-et-3-0-2.telehouse.ukcore.bt.net [109.159.252.182]
7 * * * Request timed out.
8 18 ms 18 ms 19 ms ae1-cr1.rdg.as29550.net [91.186.5.241]
9 19 ms 19 ms 19 ms port49-a.10.magic.as29550.net [94.76.199.34]
10 18 ms 18 ms 19 ms cambridge.eukhosting.net [92.48.108.230]
Trace complete.
I seem to recall in the past having to pipe hop. How would you do it on the current PN router?
Ta
Mark
22-09-2018 7:00 PM
Still busy connection wise, even after a disconnection and new gateway. Can't believe the packet loss and latency. When using these graphs before, it is unusual to see any yellow except 1/2 hourly spikes when runniung Testmynet auto tests. Even 4k streaming never showed this up. I can't believe putting a webcam in the DMZ has caused this.
23-09-2018 8:36 PM
Seems the webcam was causing the busy issues. I have put a NowTV box in the DMZ now which has brought the graph back to a more manageable range and something I can monitor a bit easier. Shame I can't just set the router to accept ping, but this will do for the time being.
- My Order
