Newbie waiting for line activation
- My Order
- Newbie waiting for line activation
01-11-2016 8:35 PM
Thank you
Re: Newbie waiting for line activation
01-11-2016 8:58 PM
02-11-2016 9:30 AM
I can see that the orders have completed, however your router isn't connecting correctly. Can you try a factory reset of the router please, there's a small pinhole on the back that you need to hold something in until the lights go out.
02-11-2016 8:45 PM
02-11-2016 8:48 PM
03-11-2016 9:40 AM
What kind of speeds are you seeing?
Based on the stats I'd expected 5-6Mb/s on speedtest, maybe a little more.
Upstream DSL Link Information | Downstream DSL Link Information | |
Loop Loss: | 24.6 | 42.0 |
SNR Margin: | 5.7 | 6.8 |
Errored Seconds: | 0 | 2 |
HEC Errors: | 0 | |
Cell Count: | 67 | 106 |
Speed: | 1091 | 7835 |
Maximum Stable Rate (KBPS): | 2272 | Fault Threshold Rate (KBPS): | 2272 |
Mean Time Between Retrains (Seconds): | 2301 | Mean Time Between Errors Upstream (Seconds): | 900 |
Indicative Line Quality: | R | Mean Time Between Errors Downstream (Seconds): | 203 |
- My Order
