New router
PabloBruno
New router
Hi, my contract was up in Jan so was offered to go onto the new Unlimited Fibre Extra package and they asked if I wanted to upgrade to the new router for £6.99.
I agreed and ordered it on 2/12/21 but I am yet to receive the new router. There is no online chat service at the moment and I don't have time to wait on the phone for 30-40 to ask where it is.
Does anyone know how long they usually take?
9 REPLIES 9
kammneves
Re: New router
Our new router only took a couple of days, Plusnet are usually very efficient.
Either way its worth the upgrade and we're very pleased with it.
PabloBruno
Re: New router
Many thanks.
Does anyone know how I can chase it up without having to sit on the phone on hold all afternoon?
Fixes: 388
Re: New router
@PabloBruno What package are you currently on, and when is your new one due to start?
Hopefully one of the PN Help Team will pick this up soon.
PabloBruno
Re: New router
Thanks - I'm on the Unlimited Fibre Extra and it has already started.
Fixes: 388
Re: New router
Ok - so you are using the Hub1 at the moment? That should be OK until the new one arrives, but as I said, this needs PN Help Team intervention.
PabloBruno
Re: New router
Yes, the old router is working fine and the speeds have improved.
Do the PN Help Team read these posts?
Fixes: 388
Re: New router
Yup, but they are a bit thin on the ground and busy so it will be later before they pick up.
bobpullen
Fixes: 331
Re: New router
@PabloBruno - apologies, your hardware order hadn't been triggered for some reason. I've sorted this and you can expect it within a few days.
PabloBruno
Re: New router
@bobpullen - Many thanks, that's quick work. Season's greetings and all the best for 2022.
