New customer router not arrived
Keith187
Hi I'm new to plusnet, I hope you're well. I have not received my router today as its my activation day. I'm left with no heating, phone tv or anything. The weather isn't good in my area, I have spoken with a plusnet advisor he was fine nothing really he can do, apparently its a warehouse issue, that's no good to me I can't be left with no heating. Any idea how to get my router out quicker or any other ideas, other than calling my home insurance? Thanks
33 REPLIES 33
Fixes: 334
Re: New customer router not arrived
@Keith187 Are you transferring from another ISP? If so, who? What service are you taking with PN?
Keith187
Hi thanks for reply, it's bt the service has now expired.
Fixes: 531
@Keith187 if you don't have a previous router that's compatible then you could pop down to your local Argos and get one of these https://www.argos.co.uk/product/4016502?clickPR=plp:2:25 , that will work fine with minimal configuration
Alternatively if you're anywhere near NG10 , I have a number of spare routers that you're welcome to collect. They're not high spec but they will work
Keith187
It's full fibre 300 Internet pn . Changing from bt 150 Internet.
Fixes: 531
@Keith187 do you still have the router ? that can be configured to work with Plusnet
Fixes: 334
@Keith187 If you still have the BT Hub, that can be temporarily used until the PN one arrives - you just need to change the credentials to your PN ones.
Keith187
Yeah I've tried it won't work. Bt have cut the service to my house now.
Keith187
I've tried
Keith187
Thanks but I can't get to argos I'm disabled and I'm in York, so thank you so much for the offer. I shouldn't of changed from bt I've been with them 25 years no issues other than a couple of cut outs. If it doesn't arrive by tomorrow I'll have to contact my home insurance, the house is freezing I've no tv or anything just 2 bars on 4g on my phone.
Thanks so much for the help.
Fixes: 334
@Keith187 The BT Hub will work with PN. Have PN advised that your service has gone live?
Keith187
Yes I keep on getting emails to tell me to plug in my new router etc, I was on the phone with pn advisor, I tried changing it on the router I still get a purple flashing light on the bt hub. It's not a new one I've had it years.
Fixes: 531
@Keith187 the BT HUb can easily be reconfiured with your Plusnet login details see here https://community.plus.net/t5/My-Router/Using-the-BT-Smarthub-6-on-a-Plusnet-Account/td-p/1587673
Fixes: 1,491
Moderators Note
This topic has been moved from Broadband to My Order
Keith187
Thanks I'll go through it again, maybe it's me I'm not that tech savvy and with my disability it makes it difficult for me. I really do need my heating on. Thank you so much for your help 🙏
