New account hub delivery
IanT
I've just got an account for broadband to be installed at our new address on the day we move in.
I'm concerned about delivery of the hub before we move in.
Is there some way to arrange for the engineer to bring it on the day everything is set up?
Moderator's note:
Duplicate post removed.
13 REPLIES 13
Fixes: 334
Re: New account hub delivery
@IanT The engineer (Openreach) will not bring the Hub, but you can ring Customer Services and ask them to redirect delivery.
NOTE: the Hubs are sent by RM Tracked24 to arrive 2/3 days before your confirmed installation date.
Fixes: 530
No, the engineer is from Openreach, the router is dispatched from PLusnet.
However, It should be possible to send the router beforehand to your current address. If you call customer support , they ought to be able to organise that.
Is this a Full fibre install ?
edit: @jab1 types faster...
IanT
Yes it's a full fibre install. Only wee problem is we're abroad at the moment until weekend!
Fixes: 530
When is your install scheduled for ?
IanT
Scheduled for 5th September, but beginning to think I'd best delay it!
Fixes: 334
Scheduled - or confirmed?
IanT
Just scheduled, date suggested by me but not confirmed yet
Fixes: 530
Is that a 'committed date' i.e a message saysing 'an engineer will install on...' or an 'estimated' i.e 'we aim to install ...' one
For a committed install on 5th Sept, the router isnt likely to be dispatched until 1st or 2nd Sept so you MAY be able to call CSC on when you're back and get the router reditected befor its dispatched. If not then one of two thing will happen:-
1) RM will post it through the letterbox (its designed to fit a standard one )
2) they'll leave a card and you can collect from the DO on 5th.
Another point I hope you realise, someone will need to be at the property when the engineer arrives ?
Possibly, but my guess would be delaying it now will push it back at least a week and maybe more depending on Openreach engineer availability in the area
edit: posts crossed, I see its only an estimated date, I'd certainly wait until you get a committed one before doing anything...
Fixes: 89
@IanT
What router do you currently have? It may just be possible to use that if the Hub2 doesn't show up on time.
Note the Hub2 fits through most letter boxes so may be waiting for you when you move in.
IanT
All I've done is selected a preferred date for install...the afternoon of the day we move into the property.
We'll be there at the preferred time so no problem there.
That's reassuring that the hub can be posted through a letterbox.
Many thanks, perhaps I was getting concerned unnecessarily
Fixes: 530
Preferred dates are just that, 'preferred' , they will often get pushed back due to Openreach engineer availability.
Assuming you've only placed the order very recently, You should get a committed date in the next day or two.
I'd wait and see what that comes back as, and then change it if not convenient...
grumble
Thinking back to my last move...
Is the current provider of broadband to the property using BT infrastructure?
If not, and there is a pre-existing ONT - how long has the ONT been powered down?
(In my case the ONT had been powered down for 3+ years, and Virgin were the broadband providers for the previous O/O's. It took twelve days after moving in to get the BT ONT 'reactivated' with an engineer visit. I had redirected the Hub2 delivery to the new property. The previous O/O's had taken delivery of it a couple of weeks previously.)
Fixes: 334
@grumble If the OP is having a NEW installation, that would strongly suggest that the current service, if there is one, is either with a non-BT provider or FTTC - BT or other. These days, as an internet connection is an 'essential', one assumes that they would have ascertained what provision is in the property during negotiations.
