New Order
mjppadiham
New Order
Hi, I am joining plusnet and my broadband is due to go live this Saturday the 17th August
I was surprised the router had not been dispatched yet in my account but then searched this and saw articles and posts in here about it being delivered a day or 2 before using a 'just in time' method'
With the go live date being a Saturday and the state and reliability of royal mail at the moment thought this does have me a little concerned as I cannot afford to have the broadband go down for the weekend
Is there anything that can be done to double check or expedite router dispatch a little? Already if it was dispatched now the earliest would be arriving Wednesday (Thursday, Friday and go live day Saturday) so it seems very tight and is a bit concerning
8 REPLIES 8
Fixes: 387
Re: New Order
@mjppadiham Hubs are despatched via RM Tracked24, which has high priority. You will receive a notification of the despatch by email and/or text, which will include the tracking number
Fixes: 118
Re: New Order
@mjppadiham
When it is dispatched you get an e-mail to tell you which contains a Royal Mail tracking number.
What router do you have at the moment. PN has always been happy for customers to use their own equipment if suitable.
mjppadiham
Re: New Order
Thanks that's interesting! I'm currently on talk talk fibre 65 with the TalkTalk Wi-Fi Hub
So if this is compatible would this work automatically after the switch or would I need to enter the new credentials / reconfigure should the plusnet router be late?
Fixes: 387
Re: New Order
In that case, you will have to wait for/use the Hub2 - the TT Hub is locked to that ISP.
Fixes: 118
Re: New Order
@mjppadiham
You will need to reconfigure the PN router so it uses your current WiFi network id - that or change all your devices.
Fixes: 387
Re: New Order
@bmc The OP has an incompatible TALKTALK hub.
Fixes: 118
Re: New Order
@jab1
I appreciate that he currently has an incompatible router.
However the PN router will be set with its own WiFi SSID while the OP's devices will be using something else.
One or the other needs to be reconfigured.
Fixes: 387
Re: New Order
Fair enough, @bmc , but that point has not been raised as a question by the OP - yet, and depends on hoe 'connected'  his home is.
