New Fibre upgade
eeje
New Fibre upgade
On the 6th December 2016 my account was upgraded to unlimited fibre up to 38mb.
Before the upgrade went live there was a note on my account saying that there was a order for 21CN ?.
I am a little confused as my line speed is now 21mb and no were near  the 38mb I was expecting  ( BT line check and other sources states the line is good for 46mb max).
has my line been upgraded to 21CN and not FTTC or will this speed increase given time Huh
11 REPLIES 11
MatthewWheeler
Fixes: 436
Re: New Fibre upgade
I'm looking into this for you.
 Matthew Wheeler
eeje
Thank you
MatthewWheeler
Fixes: 436
Our tests are showing what's known as a bridge tap which can sometimes be a sign of a internal issue.
Can you confirm the router is connected to the master socket?
 Matthew Wheeler
eeje
Yes it is connected to a new BT master socket ( the type that has a built in filter).
This was fitted by BT about two months ago when they were investigating a slow connection before this upgrade.
This didn't work and they said they had to swap the line over at the exchange, all was good after that.
MatthewWheeler
Fixes: 436
In that case I'd recommend raising a fault here so we can get that looked into.
 Matthew Wheeler
eeje
Thanks Matthew, ill have to do this when I get home.
eeje
I have raised a ticket.
But When I ran the BT line check last night the "IP Profile for Line is" said 24mbps.
Could my profile be set at the wrong speed???
Anoush
Aspiring Hero
Fixes: 139
Testing your broadband, the router is in sync below the estimated speed range.
As I'm not detecting the cause, the next step would be to arrange an engineer visit. I've updated your ticket, if you reply to with the requested information we'll get it booked in for you.
Also, there is no banding applied:
Profile Name 0.128M-40M Downstream, Error Protection Off - 0.128M-2M Upstream, Error Protection Off
This is my personal Community Forum account to help out around these parts while I'm at home. If I'm posting from the 1st March 2020, this means I'm off-duty with no access to internal systems.
eeje
Thanks, I've just updated my Ticket so you can book a engineer.
Anoush
Aspiring Hero
Fixes: 139
All booked, @eeje for tomorrow between 8am and 1pm.
Feel free to let me know how it goes.
eeje
Thanks, will do
