Need a delayed order to be dealt with.
Fixes: 1,607
Re: Need a delayed order to be dealt with.
Cool. That's booked for you now. The engineer should be visiting you anytime between 8am to 1pm on Monday.
I've set a reminder to follow up with you then but feel free to get back to me with how it goes.
Jayjay
Thanks, be glad when it’s fixed for good
Fixes: 1,607
Absolutely!
Fixes: 1,607
Just checking back. I can see the engineer fixed a problem at the cabinet (the green box in the road) and you look to be back up and running. Is everything working OK now?
Jayappleaddict
All seems to be working! Thanks
Fixes: 1,607
Excellent, that's a relief. Is there anything else I can help you with?
