My previous supplier thinks I have cancelled the change to plusnet?
- My Order
- My previous supplier thinks I have cancelled the c...
22-04-2018 8:27 AM
Hi, ordered a plusnet fibre optic and line package back on the 9th of April but just got an email from TalkTalk thanking me for staying with them, which was a bit of a surprise to me as I certainly made no such decision! What's going on here, Is the order still going through? If so why are talktalk under the impression i'm staying with them?
Re: My previous supplier thinks I have cancelled the change to plusnet?
22-04-2018 2:46 PM
22-04-2018 7:47 PM
I find replies like this totally unacceptable, you have ordered something, why has it failed? I think it is to do with PlusNet's and BT Wholesale's archaic ordering systems which are incapable of dealing with perfectly valid orders. So will replacing the order somehow solve the problem, not really, it seems to be a case of try and try again and it may work. Then another customer will have the same problem in the next few days or weeks and the same thing happens again. PlusNet should be able to do better than this.
23-04-2018 7:58 AM
23-04-2018 12:39 PM
Yeah, but that doesn't really solve the issue of what stopped it going through, I'm fine with the process being restarted but what's going to stop it going wrong again and is the first I'm going to hear about any issue going to be an email from my old supplier?
23-04-2018 3:57 PM
Just recieved yet another email from talktalk thanking me for choosing to stay with them. Less then a day from the order being resent! What's going on?
24-04-2018 10:09 AM
Hi there.
Sorry to hear your orders are failing within our suppliers systems.
From what I can see the order we placed yesterday is still open but it's in a delayed state.
I've moved ticket 173009162 into my workflow so I can keep an eye on this for you.
I'll let you know when we receive an update.
24-04-2018 3:12 PM
Looks like your order kept failing because our supplier systems were automatically assigning the number port to complete on the 7th May which is a bank holiday thus causing the number port to be rejected and ultimately the order itself.
They've manually resubmitted the number port for a different date.
We should receive confirmation of the completion date within 24 hours.
24-04-2018 6:33 PM
Have received both completion date and in the past hour yet another email from talktalk thanking me for staying with them (The 3rd so far). Hope everything is still on track? Not inspiring so far!
26-04-2018 1:48 PM
- My Order
