My order
Fixes: 1,599
Re: My order
That was the initial order that unfortunately was cancelled by the existing provider of the property.
The order was then replaced and went into a delayed state and cancelled afterwards. When the order was replaced again [which completed], broadband wasn't placed as part of that order so we had to place it separately.
In light of the continued delays you've experienced, I'll see what I can do to speed things along.
Stevec700
Re: My order
Ok, thank you. Broadband came on today and, whilst I am very grateful for your successful efforts to shorten the stated connection time I would ask why was I being told "a minimum of 4 days " is the suppliers timescale? It is this kind of misinformation ( amongst other issues)that makes people , including me, question either the individuals or the organisation as clearly with a little effort ( again thank you) it is obviously NOT the minimum.
regards.
Chris
Legend
Fixes: 169
Re: My order
4 working days is the minimum leadtime set by our suppliers, that's the earliest timescale we can place orders for. I'm glad to hear you're online now.
Stevec700
Re: My order
Fine, could you please tell me why the service at the previous address is still live? This was a transfer and, based upon the dates , should have been terminated.
Fixes: 1,599
Re: My order
I've sorted that now, it should be ceased within 24 hours.
