My newly placed order.. I'm confused
FIXED- Subscribe to RSS Feed
- My Order
- My newly placed order.. I'm confused
24-11-2017 1:48 PM
Hi all
Yesterday I were going to order Plusnet but I didn't quite get round to it but when I added everything to my cart it said I would need an engineer to come out for £49.99 and today when I did everything the exact same, it didn't mention an engineer and didn't show in my cart? Before it took me to my order it asked if I had a BT socket (which I do).. I literally did everything the exact same as yesterday, could someone help me please? It would be great if I didn't need the engineer.
Fixed! Go to the fix.
Re: My newly placed order.. I'm confused
24-11-2017 2:01 PM
£49.99 is the charge to provide a new line
24-11-2017 2:14 PM
24-11-2017 2:19 PM
If the line is not active I believe you would have to pay the new line provide charge, but if an engineer needs to visit would be down to BT Openreach to decide.
24-11-2017 2:38 PM
24-11-2017 3:42 PM
@coreymall96 Do you know what your phone number is?
24-11-2017 4:42 PM
on 24-11-2017 9:41 PM - last edited on 25-11-2017 1:03 AM by Mav
Have you confirmed it is working? If the phone isn't working, your broadband certainly won't.
If it is, however, you should not need an engineer visit.
Moderator's note by Mike (Mav): Full quote of preceding post removed after two posts were removed as per Forum rules.
24-11-2017 9:53 PM
24-11-2017 10:51 PM
24-11-2017 11:14 PM - edited 24-11-2017 11:14 PM
Cheers for the details.
It looks like we just restarted a recently stopped BT line at your address, which took just over 1 hour and is possibly the quickest I've ever seen a phone line to be reactivated as these type of orders usually go through next working day.
We then swiftly got the broadband order in place, was accepted by our suppliers promptly and is due to complete on the 27th.
Again these type of orders usually bear a lead time of 4 working days. I'd hazard a guess that the equipment in the exchange was left semi-active when the line was ceased, so it's a relatively easy and quick process to reactivate the services.
Whilst this doesn't explain why we wanted £49.99 the first time you tried to sign up, if you selected all the same options both times, it's possible the system didn't detect the stopped line initially.
Let us know how it goes on Monday!
24-11-2017 11:23 PM
24-11-2017 11:26 PM
No problems, aye indeed.
I'll check up on things when I'm in the office on Sunday.
Hopefully your router (assuming you've ordered one) arrives in time for the unexpected early activation.
25-11-2017 1:04 AM
Moderator's note:
Two off-topic and unhelpful posts removed.
Forum Moderator and Customer
26-11-2017 3:45 PM - edited 26-11-2017 10:54 PM
We'll let you know when your broadband connection is ready to use and fingers crossed your router doesn't take too long to arrive. It should be in the post soon. -Anoush
EDIT: Changed date from the 24th to the 27th.
- My Order
