Moving from TalkTalk LLU
- My Order
- Re: Moving from TalkTalk LLU
10-02-2018 9:10 PM
Hello, I've finally bitten the bullet to try switching from Talktalk - the only point that's been holding me back has been concern over the number switching.
The initial step of the PlusNet process (and all other providers) flashed up a note that our phone number may not move across. From some research this is because of it being on TalkTalk LLU and so not registered in the same way - but that it should be resolvable (eg https://community.plus.net/t5/My-Order/Considering-moving-from-TalkTalk-LLU-to-Plusnet/m-p/1334660)
My main question is, other than crossing my fingers, is there anything we need to do that could increase the likelihood that we keep our number?
10-02-2018 10:56 PM
Hi there Swamprat.
The only thing I can say is that I too came over from TalkTalk and left Plusnet to do there thing. My number was initially given to me by TalkTalk but was swapped over without a hitch. The only advice I can give you is let Plusnet handle it and all should go well.
Growing old is inevitable...But growing up is optional.
12-02-2018 6:43 AM
Thanks, I'll do that then and hope it does
15-02-2018 6:46 PM
