Modem Advice, Moving from Virgin Media
cpressland
Hi Everybody,
I've just switched from VM to Plus.net and my intention is to continue to use my EdgeRouter X rather than the Plus.net Router. but I just wanted to confirm if I need to order an Openreach ECI / Huawei modem or if Openreach will bring one with them when I get the new line installed?
5 REPLIES 5
Fixes: 356
Re: Modem Advice, Moving from Virgin Media
Openreach don't supply the modem any more, and you can't order one from PlusNet. They are available on a well known auction site. PN now supply the Hub One (similar to the BT Home hub 5) which is a combined modem/router and, no, it's not possible to configure it in modem only(bridge) mode.
cpressland
Understood, thanks, I'll order one from that popular auction site.
Fixes: 356
If you wanted a brand new VDSL modem there are a couple out there https://www.broadbandbuyer.co.uk/store/modems/vdsl-fibre-modems/ .
There's also a few modem/routers out there that will operate in bridge mode. I use a TG589n in the office bridged to my firewall, works fine.
cpressland
Thanks - I was originally considering buying the Draytek over the Openreach modems but after trolling the forums here for a while I'm not convinced it's worth the extra expense. Do you think there are any notable benefits for using third party hardware over vanilla openreach hardware?
ejs
Aspiring Hero
Fixes: 25
Third party devices generally use slightly newer chipsets than what's in the Openreach modems.
The Openreach modems also won't get any support (firmware updates) for much longer.
