Left with no broadband
fowle
As a new customer I have a go live date of today and my old supplier has turned thier service off, so now left with no broadband at all and trying to work from using my mobile data.
10 REPLIES 10
Fixes: 380
Re: Left with no broadband
@fowle I know you have posted in the Full Fibre board, but are you actually having that installed, or is this merely an FTTC to FTTC transfer? If so, the fact that your old ISPs connection has ceased would indicate that the transfer is happening, but note that it can take up to 23.59 of your transfer date for all the actions to complete - although this usually happens quicker.
fowle
It is a transfer
Fixes: 1,495
Moderators Note
This topic has been moved from Full Fibre to My Order
Fixes: 380
@fowle wrote:
It is a transfer
OK - so just be patient, if nothing has changed by around 9M, post back.
Have you connected the Plusnet Hub, or are you using a third-party kit?
fowle
Connected the plusnet hub and the light goes from green to orange
Fixes: 380
OK - leave that connected, wait - as advised earlier - and see what happens. If you are moving from a different ISP, there are changes required in the BTw/OR routing as well as the need for the PN systems.
SammyM
Fixes: 101
Hiya @flowle,
The order is due to complete today and is on track. There will be a short downtime while the engineer swaps over your service.
It will complete by midnight today.
 Sammy M - Sheffield Team
Fixes: 380
@SammyM - as I think I advised the OP earlier.😉
fowle
@jab1 yes you did advise the same.
SammyM
Fixes: 101
You did @jab1 Cheesy I was just being your backup haha
