Just ordered Fibre and Phone
ashokpatel123
Hi
Placed an order yesterday for the 38/2 fibre and home phone.
I want to keep my phone number (currently supplied by BT/SSE and not virgin fyi) - will this be moved over?
As I am coming from Virgin Media, I have no connection active on this line. How long will it take to get fibre up and running?
So far there are no updates on the order.
21 REPLIES 21
Fixes: 1,600
Re: Just ordered Fibre and Phone
It looks like we sent you an email this morning with the status of the order? You can view the service notice here. The transfer should complete on the 12th July.
Anoush
ashokpatel123
sorry , I read the email, it says I can keep my number.
last question. email just mentions phone. Does it mean the fibre will go live on the 12th as well?
Fixes: 1,600
If you're referring to the number ending in 035, the email confirms that yep.
ashokpatel123
Thanks - is the fibre go live on the same date? as the mail just mentions home phone. thanks
Fixes: 1,600
Yep, that's right. Apologies for the lack of communication surrounding the fibre order.
It should go live at any point up to midnight on the day.
ashokpatel123
Hi
Activation is in a weeks time, I just want to check and make sure that the router will be dispatched before then.
thanks
MatthewWheeler
Fixes: 479
I've manually ordered this for you.
You should have it by the day of your transfer.
 Matthew Wheeler
ashokpatel123
thank you!
Fixes: 1,600
No problems, let us know how your activation goes.
ashokpatel123
Router received Smiley
Roll on activation on 13th!
Fixes: 1,600
Awesomeness, let us know how it goes Grin
ashokpatel123
Phone has been activated...now just waiting patiently for the fibre Smiley
Fixes: 1,600
Almost there... it should go live at any point up to midnight.
ashokpatel123
Indeed!
One weird thing is that the Account Summary section says the order is 'complete' but the order tracking section says the fibre won't go live until the '13/07/2017'...
