Joining plusnet
FIXED- Subscribe to RSS Feed
- My Order
- Joining plusnet
09-06-2017 4:11 PM
Fixed! Go to the fix.
Re: Joining plusnet
09-06-2017 6:13 PM
Welcome to the community forums @Brian28.
I've had a look over your orders and our suppliers seem to have advised that they should be able to complete the installation without an engineer accessing the property.
However I'm afraid that the request to delay the activation to the 20th did go through on the broadband side of things, so although the phone line should activate on the 13th, the broadband isn't expected to be online until the 20th.
Although the notification came through from our suppliers around 1 minute before the first advisor tried to change the date (So it's likely they already had the order open and had not seen the update come through) I am sorry to see how this has been handled by other advisors following this and have passed feedback on to the relevant people.
The initial fees cover the cost of the the first month of service from when it activates, so ultimately you should end up only paying for the time the service is actually active.
I hope this clears things up.
Re: Joining plusnet
14-06-2017 5:46 PM
Re: Joining plusnet
14-06-2017 6:50 PM
I've just called our suppliers to confirm. The appointment is all booked in for 20th June between 8am and 1pm.
As usual, it can take anytime up to midnight for the services to go live.
Re: Joining plusnet
14-06-2017 9:04 PM
Re: Joining plusnet
15-06-2017 11:31 AM
As per my previous reply,
The engineer will need access to your property to complete the work.
As such, the line installation fee is applicable.
Re: Joining plusnet
15-06-2017 9:45 PM
Re: Joining plusnet
16-06-2017 10:01 AM
Hi @Brian28, sorry to see your order has gone back to needing an appointment, however the information we have provided you has been correct and truthful based of off the information we had from our suppliers at the time.
On 02/06/17 11:54:08, our suppliers notified us that an appointment was not required on the order.
On 13/06/17 15:03:10, our suppliers notified us of a delay on the order and advised that we needed to re-book an appointment.
Apologies for any inconvenience this has caused, however we have simply provided updates that we have received from our suppliers.
Re: Joining plusnet
20-06-2017 8:35 PM
20-06-2017 8:43 PM
Re: Joining plusnet
20-06-2017 9:02 PM
Re: Joining plusnet
21-06-2017 10:43 AM
Hi Brian, you need an aerial for the freeview channels, catch up is over the broadband (not wifi, it needs to be ethernet cable to the box).
Re: Joining plusnet
23-06-2017 8:11 PM
Moderator's note by Mike (Mav): I have changed the fix to @Gandalf as per message #10.
Forum Moderator and Customer
