Is BT lying or is Plusnet having me on?
FIXED- Subscribe to RSS Feed
- My Order
- Is BT lying or is Plusnet having me on?
17-07-2021 10:33 AM
I've just signed up to Plusnet because I can only get 5mb download from BT and it just isn't enough for this household. Plusnet have guaranteed 20mbps download speed, with an expectation of more, but when I told BT this they say that if they can't get more than 5mb, Plusnet won't either, as they both use the same lines. I'm wondering if this is just a sales tactic or if I'm going to get a message from Plusnet changing the guarantee. Anyone else had this?
Fixed! Go to the fix.
Re: Is BT lying or is Plusnet having me on?
17-07-2021 11:15 AM
Put your phone number in the following and see what it says for your house.
17-07-2021 11:17 AM
@Layoes Welcome to the forums. If you post the result of this site:BT Broadband (ensuring your phone number is obscured), someone will be able to explain your options.
17-07-2021 11:22 AM
Is this enough info?
Featured Products | Downstream Line Rate(Mbps) | Upstream Line Rate (Mbps) | Downstream Handback Threshold(Mbps) |
WBC FTTC Availability Date | WBC SOGEA Availability Date | Left in Jumper | ||
High | Low | High | Low | |||||
VDSL Range A (Clean) ![]() |
34.1 | 26.5 | 6.6 | 4.7 | 22.6 | Available | Available | -- |
VDSL Range B (Impacted) ![]() |
33.4 | 22.4 | 6.5 | 4.3 | 18 | Available | Available | -- |
Featured Products | Downstream Line Rate(Mbps) | Upstream Line Rate (Mbps) | Downstream Range (Mbps) | Availability Date | FTTP Install Process |
FTTP on Demand | 330 | 50 | -- | Available | -- |
ADSL Products | Downstream Line Rate (Mbps) | Upstream Line Rate (Mbps) | Downstream Range(Mbps) | ADSL Availability Date | WBC SOADSL Availability Date | Left in Jumper |
WBC ADSL 2+ | Up to 15.5 | -- | 13.5 to 18 | Available | -- | -- |
WBC ADSL2+ Annex M | Up to 15.5 | Up to 1.5 | 13.5 to 18 | Available | -- | -- |
ADSL Max | Up to 8 | -- | 7 to 8 | Available | -- | -- |
WBC Fixed Rate | 2 | -- | -- | Available | -- | -- |
Observed Speeds | VDSL |
Max Observed Downstream Speed | 6.1 |
Max Observed Upstream Speed | 0.56 |
Observed Date | 2019-12-18 |
Other Offerings | Availability Date |
VDSL Multicast | Available |
ADSL Multicast | Available |
Premise Environment | Status |
Bridge Tap | N |
VRI | N |
NTE FacePlate | N |
Last Test Date | 10-07-2021 |
Exchange Product Restrictions | Status |
FTTP Priority Exchange ![]() |
N |
WLR Withdrawal ![]() |
N |
SOADSL Restriction ![]() |
Y |
17-07-2021 11:28 AM
That table says you can get good ADSL and reasonable FTTC - why BT told you what they did is beyond me.
17-07-2021 11:41 AM
Thank you both. I can't pretend to understand what all the figures mean, but Plusnet are starting my new service on the 28th, so I wanted to check up.
17-07-2021 11:42 AM
Moderators Note
This topic has been moved from Fibre to My Order
17-07-2021 11:47 AM
Assuming you ordered FTTC (this shows as VDSL on the results) you look at the high / low figures.
This shows PlusNet's minimum speed guarantee of 20 is just below what OpenReach are saying for your line.
17-07-2021 11:50 AM
Just had another look at the results. Further down there's a section called Observed Speeds.
Here it says the maximum observed on the line (under VDSL) is 6.1 - this could be where BT is getting their number from.
17-07-2021 11:56 AM - edited 17-07-2021 12:03 PM
What these figures are telling me is that either this information is wrong OR you have a fault on your line. You should be getting 26.5 Mbps minimum but are currently syncing at 6!
Do not be surprised if this fault transfers with you. If it does you will need to report a fault.
If you have a Smarthub 6 and you won’t be charged for not returning it then keep it as it can be used on your Plusnet service. They are better than Plusnet’s offerings. You will find setting instructions pinned to the top of the Router board.
Edit the last test of your speed was in 2019 and appears not to have been checked since. It sounds like you have been living with this situation for a couple of years.
Once transferred do come back here if you want advice on getting the best speed from your connection.
17-07-2021 11:58 AM
Yes, I wondered that - but you'd think BT would know what they're talking about, wouldn't you? I've just checked again with my neighbour, who also has BT, and he gets c27mbps, so why they kept insisting I couldn't have it is beyond me. Anyway, Plusnet is cheaper! (and they have a nice forum).
Thanks for your help.
Jill
17-07-2021 12:06 PM - edited 17-07-2021 12:11 PM
Thank you. I probably will have to come back! I'm pretty sure I've had the line checked a couple of times before and they've said there was no fault, but I might try and do it again while still with BT.
Actually, I have reported it as a fault about a week ago, but they haven't looked at it yet.
17-07-2021 12:38 PM
@Layoes As Baldrick suggests, keep your BT HH6 if you can, though a year or two back BT said they would charge new customers who did not return their Hub on leaving. Otherwise while you are waiting you might like to source one via Gumtree or eBay, they fetch around £5-£25 and many of us find they have far better wifi than Pnet's Hub One which is basically the old HH5 in a cheap dress. Advice aplenty on this forum which as you say is a friendly one! Hope all goes well on the day.
17-07-2021 5:59 PM
Forum Moderator and Customer
17-07-2021 9:26 PM
- My Order
