How much downtime can I expect switch from Bt to plusnet?
FIXED- Subscribe to RSS Feed
- My Order
- How much downtime can I expect switch from Bt to p...
Re: How much downtime can I expect switch from Bt to plusnet?
16-02-2022 9:28 AM
I've migrated FTTC services twice in the last 12 years. In both cases there was actually an overlap between ISPs, in other words the username/password of the outgoing and incoming ISPS were both valid on the migration day.
The last time I migrated (to Plusnet) was 9 years ago, so maybe things have changed since, and it's become more clunky !?
21-02-2022 2:44 PM
21-02-2022 3:15 PM
@lennon49lennon That doesn't sound correct - Plusnet only supply combined phone+broadband - the requests go in together. Unless someone can prove me wrong? @MisterW ?
21-02-2022 3:29 PM
21-02-2022 3:57 PM
This requires investigation - @Gandalf ?![]()
21-02-2022 4:03 PM
21-02-2022 4:52 PM
21-02-2022 5:03 PM
BT are just claiming plusnet did not cancel as per their advertisement saying they would
@lennon49lennon Complete and utter rubbish!. Plusnet don't inform BT directly, they place an order with Openreach/BTWholesale to transfer your services. Your existing ISP (BT retail in this case) is automatically informed by Openreach/BTw of the transfer. It would seem that BT Retail's systems have 'lost' the notification. As I said, its not possible for them to have been supplying your broadband as well as PlusNet.
If there's any arguments from BT then I'm sure one of the PlusNet help team will be able to provide the details of their order and transfer date.
21-02-2022 5:12 PM
21-02-2022 5:21 PM
They said they couldn’t email me anything to prove they had advised BT to cancel.
Technically that's true, because they don't advise BT of the cancellation directly. What they do have is the order details and the date Openreach/BTw completed the transfer.
John @jab1 tagged one of the help team earlier, so I'm sure they will be along shortly...
21-02-2022 5:22 PM
@lennon49lennon No disrespect to the call-centre staff you spoke to, but they don't have the authority or ability to do that, as @MisterW said, one of the Help Team on here will be able to sort this for you.
21-02-2022 5:37 PM
BT have past form for this kind of thing, when I left - a few years ago now they tried to charge me a leaving charge. I had a battle on my hands until I started using and quoting their own rules.
So in this case, as has been pointed out, they need to check their systems and Openreach, where they will find they are in the wrong. Don’t let them fob you off, if the first person you speak to can’t see the info, ask to be transferred to second line, or a uk based customer service advisor. They do have some competant staff, sometimes it is a struggle to get to them.
The latest ofcom rules state moves can be done in days, seems they have work to do.
21-02-2022 8:24 PM
I'm really sorry to see BT are still charging you for a broadband service.
I've had a look into this for you and I can confirm that we've transferred both your phone & broadband service across to us that completed on the 11/02/2022 at 07:27 which should've triggered a "leaving notification" their side. I've attached a screenshot of the completed broadband order onto a support ticket I've created on your account Here which I hope helps.
I'd recommend calling BT and asking the adviser to check the supplier/wholesale systems for a cease order.
Let me know how it goes.
22-02-2022 10:05 AM
22-02-2022 10:12 AM
@lennon49lennon As per my and other previous responses, I know it may be stressful, but stick to your guns, BT are wrong, demand your refund from the 11th.
If you broadband has been working via the PN router since that date, there is no way BT could be supplying it.
- My Order
