How long does it take to upgrade a package?
Jellybean180
Hello, I hope this is in the correct place.
I've upgraded my fibre package to an increased speed package. It is saying
You can't change your products for the moment, you already have a product change in progress.
Which is fine, I'm just curious on how long it normally takes for the changes to take effect?
Not waiting for any new hardware or anything just a package upgrade.
Thanks for any info or guesses.
1 REPLY 1
Mav
Fixes: 507
Re: How long does it take to upgrade a package?
Moderator's note(s):
Thread moved from Fibre Broadband to My Order.
Forum Moderator and Customer
