How long do I wait??
Pauper123
I am beginning to regret getting in touch on the 2nd of this month to change over to fibre. I received the router a couple of days later so silly me thought everything else would be completed just as quickly.
Now, three weeks and four phone calls later I am non the wiser as every time I speak to someone they tell me it’s another department which is very annoying after waiting for over an hour each call.
I would like to know from ANYONE who has the answer ....how long is too long???
Thanking everyone in anticipation
Phil
8 REPLIES 8
Fixes: 1,483
Re: How long do I wait??
Moderators Note
This topic has been moved from Fibre to My Orders
LaurenB
Fixes: 131
Hi @Pauper123, I am sorry for the issues you have experienced. Your Fibre order has complete, but testing the line has detected a phone fault.
I've raised this to our suppliers and created a fault ticket you can view here.
 Lauren Barry
Pauper123
Thank you but the link doesn’t work and the only ticket on show is the one from the 11/12/18
Regards,
Phil
HarryB
Fixes: 256
Sorry Phil, please disregard the previous response as I think it may have been intended for someone else.
Unfortunately it looks like there's currently a data mismatch somewhere in Openreach or BT Wholesale systems which is causing the incorrect postcode to be assigned to your phone line and this is preventing us from placing the modify order from ADSL to Fibre.
I've raised this with our suppliers to correct the issue and I'm monitoring this via a ticket on the account Here.
I'll make sure the order is placed as soon as possible and get an order in place as soon as we're able to for you.
I do apologise for the poor communication on this causing delays. Thank you for your patience.
 Harry Beesley
Pauper123
Hi Harry,
Thanks for doing this .
phil
HarryB
Fixes: 256
No problem, hopefully we're not waiting too long for the records to update.
 Harry Beesley
Pauper123
I was contacted two days ago by a Openreach engineer who said they would do the switch yesterday now that they had the correct details . As per usual that day has come and gone without any notification from anyone so I presume we’re back to square one.
Anyone want to elaborate?
OllieC
Fixes: 46
Hi Pauper123@
We're really sorry that you are experiencing a technical delay.
I have chased this up for you today and updated your complaint ticket here
Kind Regards
