How Long?
Harro
How Long?
I am on Fibre 500 and took up the upgrade to Fibre 900.  How long does it normaly take to increase the speed as its been 3 days now and im still on Fibre 500.
Thanks Smiley
Tags (1)
9 REPLIES 9
Fixes: 585
Re: How Long?
@Harro the speed should increase as soon as the upgrade order completes.
First thing is to login to your account and check if your product has changed to 'Full Fibre 900'.
Assuming that has changed, then are you doing wired speed tests ?
Unless you've got a Wifi 6 capable router ( which the PN HUb 2 is not!) and Wifi 6 client , then you will struggle to get much > 400Mb wireless.
Tags (1)
Harro
Re: How Long?
Hi MisterW
Thanks for the reply.
Ive been checking all week on my account and it still says Fibre 500.
Ive also been testing on Wired connection and still getting 500Mb
Tags (1)
Fixes: 585
Re: How Long?
Doesnt sound like the upgrade order has been processed yet then. It should only take 24 hrs once the order is processed. I'm not sure these days, whether upgrades are processed immediately or they wait till the billing date ?
Tags (1)
Fixes: 1,495
Re: How Long?
Moderators Note
This topic has been moved from Full Fibre to My Order
Tags (1)
James30
Fixes: 32
Re: How Long?
@Harro -Hiya, I can have a look at that for you, can you PM me your username please. Thanks
James - Plusnet Sheffield
Tags (1)
Harro
Re: How Long?
Hi James
PM sent
Thank you
Tags (1)
James30
Fixes: 32
Re: How Long?
@Harro - Brill thanks. I've left you a ticket HERE if you want to take a look. Cheers
Tags (1)
Harro
Re: How Long?
Thanks James
Ill take your advice tomorrow
Thank you 👍
Tags (1)
James30
Fixes: 32
Re: How Long?
No worries, give me a nudge if you need a hand with anything else. Cheers
Tags (1)
