House move- phone line active but no fibre?
FIXED- Subscribe to RSS Feed
- My Order
- House move- phone line active but no fibre?
08-09-2020 6:47 PM
My fibre/phone is due to come on today (after a 2 week delay due to plus net)
I received a text at 11.30am saying my phone line has been active but nothing for the broadband nearly 7 hours later? Is this normal?
I know it says to wait until midnight but I need to make arrangements to go into the office if I know it won't be working by tomorrow morning.
Josh
Fixed! Go to the fix.
Re: House move- phone line active but no fibre?
08-09-2020 8:17 PM
Yes it's normal as you say it is up to midnight for the Broadband to be made active, you can check here https://www.broadbandchecker.btwholesale.com/#/ADSL
look for the info at the bottom it will say if the order is still pending and what date it's expected to be done.
08-09-2020 8:34 PM
08-09-2020 8:55 PM
Yeah, Plusnet wouldn't be able to do anything before then, if you're still getting nothing after midnight they can raise a fault for you.
08-09-2020 9:59 PM
This topic has been moved from Fibre Broadband to My Order.
Customer and Forum Moderator. Windows 10 Firefox 84.0.2 (64-bit)
09-09-2020 7:06 AM
09-09-2020 9:52 AM
Really disappointing service from plusnet, its now going to be over 2 weeks later than the date originally stated by the move team.
Less than ideal when there are 2 people working from home full time, and have had to make various short term plans to find alternatives to working from home.
09-09-2020 11:38 AM
I'm having the exact same issue, I haven't got to the possibility of a fault yet but that checker says available. Who told you about the fault, BT or Plusnet?
09-09-2020 12:31 PM
10-09-2020 9:49 AM
Can I ask, will my Broadband be working 72 hours within the fault raise date, or will it simply be an update?
Is there an approximate lead time I can get on this being resolved? It is a massive inconvenience having no internet, especially seeing as my employer is working from home until the end of 2020, and special arrangements have to be made if this is not possible.
I have had to start a new contract for this house move, and am considering simply cancelling and moving to virgin, who have told me they can have me up and running in 3-5 days.
Thanks,
10-09-2020 9:31 PM
Who knows is the answer Plusnet give 72hrs but there is no guarantee at all that the fault will be fixed in that time only that they should have an answer from Openreach, not much Plusnet can do really they can only report the problem the rest is down to Openreach.
11-09-2020 3:12 PM
Rang plusnet up yesterday and they advised performing a soft cease and reprovide. Got a text from openreach later. Think they may have come to the property, unsure as I was out. All working now.
- My Order
