Help with Installing New Broadband Router
nicolakir3164
Hello, I am a new customer, who has just received my Plusnet broadband router today.    Can someone please let me know when an engineer is available to install this for me, because I need the box which goes onto the wall for the extension leads to connect my broadband router?    Thank you
23 REPLIES 23
Fixes: 388
Re: Help with Installing New Broadband Router
@nicolakir3164 . Are you with another ISP at the moment - or have you been? What service are you taking from Plusnet 'Fibre' or 'Full Fibre'?
nicolakir3164
I am using the Full Fibre 74 and I was with BT previously.    Because I thought I was unable to get broadband again, for some weird reason, I removed the box that goes into the wall, where the red and yellow leads went into, off the wall, for some weird reason, so I need a new box for the wall so I can feed the leads into that and get everything plugged in and working.  So, I need an engineer to do that for me, please.
Fixes: 388
@nicolakir3164 I am not Plusnet staff. You will need to call Plusnet and explain what you have done, as only they can talk to Openreach - the people who 'install' the 'box'.
Be aware this may cost you money, but you should be told if it is going to be chargeable.
Fixes: 585
If so, do you not still have it ?
nicolakir3164
The photo is a bit too close up for me to see the whole thing, but judging by the labels of the switches, it looks like the box I need.
Fixes: 388
As asked by @MisterW , do you still have the one you 'removed' - which you shouldn't have, by the way.
nicolakir3164
Sorry, should have said, no I do not have this box.
Fixes: 388
Oh dear! As I suggested earlier, you will need to contact PN and ask them to arrange an Openreach engineer.
nicolakir3164
Thank you for your help.
Fixes: 118
@nicolakir3164
The transfer should / may have been refused as OR do a line check to the ONT. If it is not powered up (or missing!!) then the check can't be completed.
As stated you need to phone PN. As an aside, can you log into your PN Member's page. If so, there may be a "Open Ticket" (message) under My Account or My Order.
Fixes: 388
All yours, @MisterW  / @bmc !
nicolakir3164
Sorry, I need clarification .   Are you saying that because I do not have  the box on the wall that the sale should not have gone through and that I should not have received the router today?   If that is the case, can you explain the reason why the sale should not have gone through then?
What are you suggesting I should do now?
Fixes: 585
Exactly my thoughts...
nicolakir3164
Yes, I can log into my PN members page, it has everything ready to go, it is just that I do not have the box for the wall.
