Have i made the right decision !
Alshamal1
Started this journey into the PlusnetWorld on April 6th when i singed up for full fibre, I was given a date of 31st of May connecting and patiently waited received the new router ready and the date arrived.The engineer from Openreach duly arrived at bang on 8am Wow i thought what a company! Then it went downhill quickly he proceeded to drill a hole through the wall for the fibre cable and smashed the brick face outside and when i told him I wasn’t happy he proceeded to try and cover it up with thr connection box without any success 🤷
I thought that was the bad news out of the way! He then proceeded to pace up and down out side with the phone to his ear which never looks good for about 20/30 minutes then came back and told me the ducting that Openreach had dug in under my garden to the front of my property some weeks before had no fibre in it !! So he couldn’t connect and said the ducting under the path to the Green Box 300 yds away was blocked1 and then disappeared.
After speaking with the guy across the road he had been told about the blockage weeks ago!! So made another appointment for the 5th June AM i was was up ready at 8am till 1pm no show! Spoke with Support who told me Openreach were unable to make contact with me!!yet they had been texting me every day before the appointment  to see if i wanted to change anything!! I’m now booked in for the 14th June for the next episode I’ve spoken with Sky and extended my contract for another month,I’ve come to the conclusion that whoever i chose for a fibre upgrade will have to put up with this excuse for a leader in communication 😂 I’ve been told i will get something for my inconvenience 🤞i wish I’d not bothered one unhappy Plusnet customer .
11 REPLIES 11
Fixes: 1,495
Re: Have i made the right decision !
Moderators Note
This topic has been moved from Full Fibre to My Order
ClaudiaG23
Fixes: 25
Hi @Alshamal1 I'm sorry this has happened. Sounds like this has been a nightmare for you! I'm unable to find any account with the details you have registered. Could you drop me a private message with your username on and I can take a look in to this for you?
 Claudia Garner
Mustrum
Fixes: 81
@ClaudiaG23    this is a new customer, they will not be able to send you a DM until they have a few more posts. They would however be able to respond to yours if you send one first.
HTH
ClaudiaG23
Fixes: 25
@Mustrum  I always forget to check that. Thank you for the heads up.
 Claudia Garner
ClaudiaG23
Fixes: 25
@Alshamal1 I've popped you a private message, you can reply to this with your username and I can take a gander for you.
 Claudia Garner
Alshamal1
Well this morning two guys from OpenReach sorted my Full Fibre supply issues out!
I just wished these guys had been sent on the 31st June
so far I’m well pleased.
Alshamal1
Having got my Full Fibre up and working well ! A week after all working well i got an email from support team saying that i was eligible for compensation  for delayed provision of £9.33 per day which i thought for the stress and frustration was acceptable! For the 15 days .Then to my disappointment a few days later I received another email saying it now would be £5.83 without any explanation of why the reduced amount !
and no mention of how many days compensation i would get! You can’t reply to the emails which is rubbish !
  Disappointing with this so called excellent support team!
RealAleMadrid
Fixes: 68
@Alshamal1  Raise an official complaint using the link below, they are obviously messing you about.☹️
complaints-code-of-practice
MatthewWheeler
Fixes: 503
Hi @Alshamal1
I'm sorry for the confusion caused by this.
The e-mails you've received are automatic as part of us being signed up to the Ofcom Automatic Compensation scheme as detailed here
Unfortunately, the £9.33 only applies to cases where your internet is down due to a fault on the line rather than a delayed order in which case the £5.83 applies.
I'm afraid there isn't anything we can do about the amounts as these are set by Ofcom
As of the 1st of January 2026, I no longer work in Plusne,t so I'll be unable to assist you with any queries.
pjmarsh
Fixes: 24
Here's the Ofcom version of the info that @MatthewWheeler refers to
Alshamal1
Hi Matthew Weller
No confusion on my part the emails I received were sent automatically but conversations i had were with real people ! Stating those figures to me and my partner on the phone in the car! It seems the confused are your Help Team! Very misleading at the very least !!
can you confirm the number of days I’m being compensated for as well ?
look forward to your explanation of this misunderstanding on your part!!
