Going Round in Circles!
Fixes: 730
Re: Going Round in Circles!
Thanks for getting back to me with the updates,
Yeah it seems that the stopped line we reactivated was the same line you had with BT. Sounds like Paul's arranging what's called a pair prove, which basically means an engineer goes out to physically confirm how the line is routed, and then records are updated accordingly to match that.
It's something that the fibre enquiries team can also arrange although they'd normally take around 3 working days to pick up the formwize and then advise us to allow 7 days for the pair prove.
Looks like this is arranged a lot sooner!
Dalesey
The case has been solved! Had an openreach engineer out today. Found that there was no dial tone on my line. Went to the DB and found the pair coming from my house was looped and put away as spare
When I cancelled my ADSL broadband a few months ago, an openreach engineer , while supplying a neighbour, has used my routing and put my pair from my house as spare
This is why openreach has no routing records for my line.
It’s amazing they’ve taken this long to call someone out and admit something strange is going on, instead of passing the buck and believing their records, following protocol
Anyways the records should be updated on Monday I’ll let you know
Fixes: 730
Cheers for the update, it’s odd because there are records but no fibre availability. Out of interest when you were with BT was fibre showing as available?
Either way fingers crossed the engineer’s efforts today mean this is sorted on Monday and I’ll look forward to hopefully placing the fibre order then.
Dalesey
That’s because fibre only was enabled in the cabinet after I cancelled my broadband. It was a community led voucher system that kicked the fibre project off about 2 years ago but the cabinet didn’t get fibre enabled until two months ago (after I had already cancelled ADSL to go with 4G) that’s why there won’t be any record of fibre ever been available at my property
Fixes: 730
Cheers for the clarification. Makes sense, we’ll see what Monday brings.
Dalesey
Hello. I haven't had official confirmation from openreach yet but i have just refreshed the adsl checker and can see the following now using the phone number:
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Handback Threshold(Mbps)
WBC FTTC Availability Date
WBC SOGEA Availability Date
Left in Jumper
  High Low High Low
VDSL Range A (Clean) 80 62.5 20 19 56.6 Available -- --
VDSL Range B (Impacted) 80 60 20 19 54.6 Available -- --
Fixes: 284
Thanks for getting in touch @Dalesey
I can see @Gandalf has this in hand for you and we'll confirm the go-live data as soon as.
 Matthew Wheeler
Dalesey
Yes that's great thanks
Dalesey
Good morning. Just checking that today is still the go live date?
Fixes: 730
Hi @Dalesey
Yup the fibre order is still in progress to complete today, I'll check back towards the end of the day.
