Full fibre wayleave
- My Order
- Full fibre wayleave
Full fibre wayleave
04-01-2026 12:40 PM
Im currently on a landline plan and looking to go full fibre.
I understand this would involve boxes being attached to the exterior of the property. Slight snag is im in a leasehold property and need permission for that.
I have checked with the lease owner and i have an email address that a formal wayleave request can be sent to, I don't know what the next step is for that.
How do i get the request from plusnet?
Is there anything else i need to know/provide for this upgrade?
I tried to do this last year and just ended up in a bureaucratic catch 22 and had to renew my old contract to avoid losing internet. id rather avoid doing that again, so hopefully procedures are more straight forward this time.
Re: Full fibre wayleave
04-01-2026 12:44 PM
@Benjack try using the procedure here https://www.openreach.com/fibre-broadband/fibre-for-home/ultrafast-full-fibre-broadband-to-your-apar...
04-01-2026 12:46 PM - edited 04-01-2026 12:46 PM
@MisterW Ah awesome, ill get right on it thanks
04-01-2026 1:19 PM
If you put your number in the following what does it say about the FTTP install (narrative below the results window).
04-01-2026 1:50 PM
@bmc I dont know what to put in
I have a phone number but dont really know what it is as use my mobile more often for calls
04-01-2026 2:10 PM
Click on the blue text Address Checker, will provide the same result.
04-01-2026 2:26 PM
thanks, was completely blind to that.
if i understand it right, i think i should be good to go, just need to sort the permissions issue out first
04-01-2026 2:28 PM
04-01-2026 3:48 PM
Our records show the following FTTP network service information for these premises:-Single Dwelling Unit Residential OH Feed with no anticipated issues.
FTTP is available and a new ONT may be ordered.
As a fibre priority exchange, FTTP has priority over other products if available at the address
As a WLR withdrawal exchange, product restrictions apply
SOADSL is not restricted at the exchange
For all ADSL and WBC Fibre to the Cabinet (VDSL or G.fast) services, the stable line rate will be determined during the first 10 days of service usage.
For all SOADSL services,the stable line rate will be determined during the first 10 days of service usage.
This site is in an FTTP priority area where FTTP is available but exceptionally SOGEA will also show as available to order but only at Non-Standard Premises (NSP) such as Hot site, Uninhabitable and Temporary locations. Migrations of WLR Solus (voice-only lines) is also allowed but only for SOGEA 0.5Mbps bandwidths. SOGEA 40/10 bandwidths order is also allowed.
Actual speeds experienced by end users and quoted by CPs will be lower due to a number of factors within and external to BT's network, Communication Providers' networks and within customer premises.
In order to be eligible for handback, downstream speed should be less than Downstream Handback Threshold values.
If you decide to place an order for a WBC fibre product, an appointment may be required for an engineer to visit the end user's premises to supply the service
ADSL, ADSL2+ and SOADSL availability: If shown at FTTP or SOGEA premises,ADSL, ADSL2+ and SOADSL are not available to order due to WLR Withdrawal stop sell rules. CPs should order FTTP or SOGEA. Copper products are only available by exception.Thank you for your interest
04-01-2026 3:58 PM
Thanks for the information.
It looks like there's no wayleave problem. The fibre follows the current copper overhead cable to the property and then comes down to ground level for the external CSP (Consumer Splice Point). There's a little bit of leeway as to where this goes but you speak to the installer on the day.
So long as you have the leaseholders permission then you're good to go.
05-01-2026 3:23 PM
Moderators Note
This topic has been moved from Full Fibre to My Order.
