Full fibre order not showing
crawfy
I have been sent emails saying full fibre switch is happening on the 28th Dec 22 but it’s saying “no current orders” on the order tracker.. also i notice that my current contract has been renewed for 24 months starting beginning of November 22 on my FTTC product:)
Just wanted to make sure that all is still good for the 28th for full fibre..
Many thanks
7 REPLIES 7
Fixes: 430
Re: Full fibre order not showing
Moderators Note
This topic has been moved from My Account/Billing to My Order
crawfy
Just to add that the new cable has been routed to the outside of house by OR engineer and is coiled ready to be drilled through the wall at some stage..
Fixes: 177
Take a look at the ticket history on the account (see PN Tickets below).
The FTTP provision is a multi stage install, it sounds as though the order is progressing otherwise the new cable would not have appeared.
It would be a logical guess that the FTTC service has been renewed so as to ensure...
  1. There is no break in service arising out of the marked risk of BTOR engineer resource non-availability for the installation of the FTTP service (there is a lot of that around)
  2. That the charges for the FTTC service do not "flop over" to the higher out of contract prices
MatthewWheeler
Fixes: 501
Hi @crawfy
I'm really sorry for how long it's taken to get back to you. We've been quite busy recently so it's taking longer than we'd like to reply.
I've checked the orders this morning and everything is good to go for the 28th. With regards to the contract, I'm not sure why that has happened but it will be overridden once your account changes over after the install
Let us know how you get on or if there's anything else we can help with
After the 3rd of November I will have a limited presence here as I have moved to a new role
 Matthew Wheeler
crawfy
Thank you both for your help and info..
Fingers crossed for the 28th Smiley
crawfy
Just to say all went smoothly on the day, with expected speeds almost from power up (after one router reboot)
Account details switched to showing full fibre as my product within 12 hours of finishing installation.
Many Thanks to all for the info 👍
willcutforth
Fixes: 113
Awesome, glad it's all sorted for you now.. You know where we are if you need anything else Smiley
 Will Cutforth
