Full Fibre upgraded but no speed increase.
shazzbot
Hi my speed was supposed to be increased yesterday to 500 package. Got the email it has been done but no speed increase. Everything is still the same.
14 REPLIES 14
shazzbot
Re: Full Fibre upgraded but no speed increase.
Still the same speed today.
My account shows what I should be getting but my speed says a different thing.
minkey
That's really weird. I did the same thing as you and got my speed increase before I got the email. There was a couple of disconnections at 1am for 1/2 hour and 2am for 3 mins, but I didn't have to do anything else.
I assume you've rebooted your router to eliminate any odd issues?
shazzbot
Hiya, thanks for your reply. Yeh I have rebooted 3 or maybe even 4 times now.  Hopefully it will happen soon. Meanwhile I am playing Diablo 4 to keep myself occupied. Smiley
shazzbot
Hi @adamwalker My account is now showing 550Mbps but I'm still capped at the 300Mbps Full fibre package.
ClaudiaG23
Fixes: 23
Hey @shazzbot, I've checked your account and there seems to be an issue with the order. The issue is with the Suppliers, unfortunately, we don't have a timescale of when this will be resolved.
 Claudia Garner
shazzbot
Plusnet are my supplier… And my account says upgrade has gone through, just my speed hasn’t. Didn’t have this problem 4 months ago when I upgraded from 150 to 300. What on earth is going on?
ClaudiaG23
Fixes: 23
We're just as confused as you are. Everything is showing as complete but the speeds haven't changed on the Suppliers system. This is an issue they're aware of. The Suppliers system we mean Openreach.
 Claudia Garner
RealAleMadrid
Aspiring Hero
Fixes: 59
@ClaudiaG23  Your suppliers may be aware of the issue but judging by the number of other customers who also have speed upgrades that have failed, Openreach appear to be taking their time about it, with a total lack of urgency, sounds about right for them, they seem to have no idea what escalation means.🙄
shazzbot
yeh it's rather frustrating. Been waiting since 23rd of May now.
shazzbot
Thank you for taking the time out to let me know, Claudia. Most appreciated. Smiley
bobpullen
Fixes: 316
@shazzbot - from what I can determine, your line has not been regraded Openreach side. There have been some attempts to rectify this to no avail.
I have just placed a manual order to modify the circuit which I expect to complete within a day or two. Let me know how you get on...
shazzbot
Hi @bobpullen Thank you so much. Will let you know for sure Wink
bobpullen
Fixes: 316
@shazzbot - the regrade order is now complete so feel free to give things another go.
shazzbot
@bobpullen Hiya, Yep it's looking like that did the trick! Thank you! 😁
