Fibre with no Phone package
FIXED- Subscribe to RSS Feed
- My Order
- Re: Fibre with no Phone package
30-06-2019 12:14 PM
My son just moved into a property which we assume had a working phone line
Certainly has a BT Master socket
PN providing Fibre broadband and reconnecting phone line, but a Phone package not required, going to use mobile instead
PN stated phone line connected within 2/3 days and Broadband 7/9 days
When the line has been connected, can,I do a basic check for dial tone, just to see if the exchange has been reconnected to the property
I would like to know if that works, before waiting to the broadband connection
Fixed! Go to the fix.
30-06-2019 12:51 PM
Yes. Whether you use it or not there will be a working phone line as part of the package.
30-06-2019 9:25 PM
Hi @bures1
The simple answer is yes, you could run a quick test in the property by plugging in a phone should you wish.
Openreach will run tests when activating the line but should you wish to check yourself you would be free to do so.
If you have any other questions please feel free to get in touch.
30-06-2019 9:36 PM
Moderators Note
This topic has been moved from ADSL Broadband to My order
01-07-2019 6:24 AM
Thanks to your all
I wasnt sure whether I would get dial tone or just 50v
No DT yet, early days presumably
01-07-2019 10:46 AM
05-07-2019 5:42 AM
Service was provided 3 days earlier that specified - well done
05-07-2019 9:47 AM
- My Order
