Fibre with no Phone package
bures1
My son just moved into a property which we assume had a working phone line
Certainly has a BT Master socket
PN providing Fibre broadband and reconnecting phone line, but a Phone package not required, going to use mobile instead
PN stated phone line connected within 2/3 days and Broadband 7/9 days
When the line has been connected,  can,I do a basic check for dial tone, just to see if the exchange has been reconnected  to the property
I would like to know if that works, before waiting to the broadband connection
Tags (1)
7 REPLIES 7
Fixes: 417
Re: Fibre with no Phone package
Yes. Whether you use it or not there will be a working phone line as part of the package.
Warwick
Fixes: 29
Hi @bures1
The simple answer is yes, you could run a quick test in the property by plugging in a phone should you wish.
Openreach will run tests when activating the line but should you wish to check yourself you would be free to do so.
If you have any other questions please feel free to get in touch.
Fixes: 1,483
Moderators Note
This topic has been moved from ADSL Broadband to My order
bures1
Thanks to your all
I wasnt sure whether I would get dial tone or just 50v
No DT yet, early days presumably
Fixes: 1,600
Feel free to PM me his address and I'd be happy to check this over for you
bures1
Service was provided 3 days earlier that specified - well done
adamwalker
Fixes: 221
That's really good to see! Cheers for letting us know and do please shout up if there's anything else we can help with. - Adam
 Adam Walker
