Fibre upgrade
palee1952
Fibre upgrade
I intend to drop the phone line and move to the fastest fibre available to me.  If I were to order today how long would it be before the changes are made?
2 REPLIES 2
Fixes: 118
Re: Fibre upgrade
@palee1952
First question is - what's available to you? Use the following Checker to confirm your options. For Full Fibre you need to see WBC FTTP in the left hand column and Availble (or KCI2) to the right. If it's shown there will be a narrative below the results window about the FTTP install.
Fixes: 391
Re: Fibre upgrade
According to this: https://www.broadbandchecker.btwholesale.com/#/ADSL , what services can you get? A screenshot (with your phone number obscured) but the full text at thee foot would help us to give you a fairly accurate response.
