Fibre upgrade problem
- My Order
- Re: Fibre upgrade problem
01-09-2020 11:28 PM - edited 01-09-2020 11:38 PM
Upgraded to fibre on 13/08/20, was sent two new routers for some reason. They are both hub ones and identical to router I already had so haven’t switched to either of them. Broadband speed hasn’t improved at all yet, still getting max 12ish mb/s. Can’t get through on customer service, no answer on twitter Plusnet help, no live chat available so trying here in desperation. Does anyone recommend plugging in one of the new hub ones? Can’t see point if identical to one already in use but wondered if necessary to increase speed?
Message 1 of 3
(485 Views)
2 REPLIES 2
02-09-2020 7:47 AM
Moderators Note
This topic has been moved from Fibre to My Order
Message 2 of 3
(457 Views)
02-09-2020 8:57 PM
Your existing Hub One will support both ADSL and VDSL (superfast broadband, fibre to the cabinet) but the settings are slightly different. Your new hubs should be set up for VDSL but you can change the settings yourself if you want.
ADSL
Broadband username or login name | yourusername@plusdsl.net |
Connection type or encapsulation | 'PPPoA' or 'PPP over ATM' |
Password | The password you use to log in to the Member Centre |
Virtual Path Identifier (VPI) | 0 |
Virtual Channel Identifier (VCI) | 38 |
Multiplexing method | 'VC Based' or 'VCMUX' or 'VC-Multiplexing' |
Fibre
Connection type or encapsulation | PPPoE Always On |
VLAN | Active |
VLAN ID (802.1q) | 101 |
VLAN ID (802.1p) | 0 |
https://www.plus.net/help/broadband/broadband-connection-settings/
Message 3 of 3
(416 Views)
