Fibre upgrade pending had no info
maxheadroom
I did a product change from broadband to 38mb fibre over the weekend, but I have had no email about when this may happen. All it says in account summary is pending.
Plusnet Alumni (retired) TonyMC
Re: Fibre upgrade pending had no info
Hi Maxheadroom, I have had a look into this for you & I can confirm that your Fibre upgrade is due to complete on 10/05/17. I have sent you an email & text message to confirm this. Thanks for your patience.
 Tony C
maxheadroom
Cheers TonyMC, email and text received.
yossarian74
I'm in the same boat, would someone be able to look into when my fibre upgrade is due to go ahead please?
Fixes: 541
I've just checked your fibre order @yossarian74 and I can see this is in progress for today.
The service should go live at any point up to midnight.
yossarian74
That's great, thanks for your help.
Moderator's note by Dick (Strat): Full quote of preceding post removed as per Forum rules
Fixes: 541
No problems, let us know how you get on.
maxheadroom
Fibre upgrade now active. Router syncing at 38Mbs, have done various speedtests this evening and download speed only 12.5Mps. Hopefully this will go up after the 10 day period.
Fixes: 36
@maxheadroom there is no 10 day period with fibre, either your profile has not yet been upgraded or the upgrade has not yet been completed. You could try a reset of your router, or give PN a cal in the morning.
Fixes: 541
@maxheadroom
I've updated your connection profile, can you try a reboot of your router and let me know how you get on?
maxheadroom
That's done the trick, download speed now 36.5Mbs. Thanks.
Fixes: 541
Awesomeness, good to hear. Thumbs Up
Thanks for letting me know.
