Fibre upgrade date and no router
- My Order
- Fibre upgrade date and no router
25-02-2021 10:17 PM
Re: Fibre upgrade date and no router
26-02-2021 3:02 PM
Thanks a lot for reaching out, and I'm extremely sorry for the delay with your router. I've now processed the router to be sent out via Royal Mail 1st Class Delivery and will be with you shortly.
Please be advised that you will not be charged for a fibre service which you're unable to use.
-Adam
26-02-2021 3:41 PM
26-02-2021 3:56 PM
Thanks for your response, while in some instances out router can arrive prior to the lead time of 3-4 working days, it is not guaranteed. Though I do acknowledge the inconvenience caused by an issue on our end here, to maintain a connection, are you able to use any alternate means of connectivity?
The fibre order itself is due to complete on 03/03/2021 at any point up to midnight.
-Adam
26-02-2021 3:59 PM
26-02-2021 4:04 PM
26-02-2021 4:07 PM
26-02-2021 4:22 PM
01-03-2021 4:08 PM
Are you able to check when my router will dispatch as I've not been told it has yet?
Also can the upgrade be delayed until it arrives?
02-03-2021 12:42 PM - edited 02-03-2021 12:43 PM
Router just arrived - not sure what happened with the dispatch notice as I got one this morning saying it's been sent today, but it's here so all is okay
- My Order
