Fibre upgrade. No difference
- My Order
- Fibre upgrade. No difference
Re: Fibre upgrade. No difference
26-06-2021 6:08 PM
OK, no problem. Strange thing is, I can't see any MSO for that area either.
26-06-2021 6:24 PM
26-06-2021 6:41 PM
Sorry for the delayed response, @hohoholmes . I can see there's only @TheMightyAJ as staff on line at the moment - he might pick it up - and point us to the MSO report?
26-06-2021 6:49 PM
26-06-2021 7:00 PM
Hi @hohoholmes,
I've tested your line again this evening and we're still seeing a reported outage in the area. It may be worth trying to reauthenticate your router, as sometimes an MSO can cause these settings to go awry and it's possible the results I've gotten this evening are outdated. I've included a guide on how to do this below.
1) To connect to your Hub One, you will need to open a browser and go to http://192.168.1.254
If you have any issues doing this via Wireless, we recommend trying to do it via Ethernet cable instead.
2) You should come to a page with information about your connection, click 'Settings' at the top and it will ask you to sign in with a Password. This is located on the back of your router under 'Admin Password'
3) Select the option for 'Broadband.'
4) You will see some default options, if not, please press 'Disconnect' on the right and this will allow you to change the Username and Password.
5) For your username, this should be your account username and should be in the following format: (accountusername)@plusdsl.net
Your password is your account password
6) Press 'Connect' and you should be online.
26-06-2021 7:08 PM
BT not showing any faults for any of the exchanges in the area.
26-06-2021 7:44 PM
26-06-2021 7:48 PM
Have you checked the username and password on the router - it should be in the form 'yourusername@plusdsl.net' and the password you use to access the members centre?
26-06-2021 8:17 PM
26-06-2021 8:24 PM
Sorry to hear that. I'm afraid, as a mere Community member there is little else I can suggest. Don't know if you've tried this since the alleged MSO was cleared, but the only thing I can suggest is a factory reset of the Hub. Otherwise it is a case of one of the Help team picking this up tomorrow.
26-06-2021 8:36 PM
26-06-2021 8:46 PM
Let us know how it goes, although I might not see it until tomorrow morning - had 'fun' on another forum I frequent, and need time to unwind before I go to bed.
It will get sorted, though.
27-06-2021 9:20 AM
27-06-2021 9:39 AM
I'd give Plusnet a ring, personally. I've run out of ideas, never seen a Hub1 and can't really think of much else - sorry.
27-06-2021 11:55 AM
Hi @hohoholmes,
I'm really sorry to see that you're still experiencing this issue with your service. I've tested the line again this morning and the estimated resolution time has been updated to later on this afternoon, meaning that work is still being carried out on this case. Should the issue continue into tomorrow please let us know and we'll be happy to check for any further updates.
