Fibre upgrade. No difference
- My Order
- Fibre upgrade. No difference
10-06-2021 9:38 AM
Re: Fibre upgrade. No difference
10-06-2021 9:56 AM
The hub one works on both ADSL and fibre so the chances are that it hasn’t yet been changed over. Not having a hub one I don’t know where to find it but if you log in and search through the options you will find an entry for your modulation type. You are looking for G.993.x which is fibre. If it’s G.992.x then you are still on ADSL.
10-06-2021 10:08 AM
10-06-2021 10:27 AM
Hi @hohoholmes
From the Hub One home page click on Troubleshooting > Help Desk, you should see a table with various settings, this is VDSL
23. Modulation: | G.993.2 Annex B |
Hope this helps.
Dan.
10-06-2021 10:51 AM
11-06-2021 8:21 AM
Thanks for your post @hohoholmes
I've just checked your fibre order and it should go live today. Looks like it was delayed due to engineer availability.
11-06-2021 8:50 AM
11-06-2021 8:54 AM
No problem @hohoholmes
Fingers crossed the switch doesn't take long
11-06-2021 3:00 PM
This topic has been moved from Fibre Broadband to My Order.
12-06-2021 7:53 AM
12-06-2021 2:19 PM
Hi @hohoholmes, thanks for getting back to us and I'm sorry to hear the speeds of your connection don't look to be where we'd expect them to be with currently only 18.7Mbps download reaching your router despite the estimates for your line being 22 - 36Mbps. During the first few days/week or so of a connection we can see the training period impacting the speeds however we wouldn't expect the speeds to drop so much below your estimates so I beleive there's something out of place somewhere which may be causing this.
Our testing from this side isn't highlighting any fault locations or what looks to be behind the missing speed so firstly , if you could please run through the below checks your side that will help rule a number of internal factors out. Should speed issues look to persist after doing so then we'll happily look into raising a fault and progressing this issue further for you.
I'd recommend starting with basic checks here: http://goo.gl/p2tpvL
And if that doesn't help the next thing would be to rule your internal wiring out by plugging the connection into your test socket which is under the faceplate of your master socket and seeing if the speeds increase. This rules out internal wiring, face plates and extension sockets as being the cause. How to locate the test socket and set your connection into it can be found here:
https://community.plus.net/t5/Library/Testing-From-The-Master-Socket/ba-p/1322242
Should the issue look to persist after the above checks then please let us know and we'll happily look to progress this fault further for you.
19-06-2021 4:40 PM
20-06-2021 9:54 AM - edited 20-06-2021 9:59 AM
Thanks a lot for your response @hohoholmes and I'm sorry to hear that these issues are continuing to occur. Further tests on the line this morning have shown that the download speeds are below those which were estimated, but above those which were guaranteed on your contract. A line issue has also been detected on various days, but the source of this issue remains unclear at this stage.
The line also appears to be dropping out quite often, but it's unclear as to whether this is when you're doing your tests on your end. I'd personally suggest raising this matter to Openreach, and arranging an engineer appointment for further investigation, however we'd need confirmation on the account that you've gone through the troubleshooting steps which have been outlined, and that you accept the possibility of an engineer charge should the fault be found to be internal.
I've created an open Ticket on the account which you can respond to via your online Member Centre. give me a nudge once you've responded and I'll be happy to pick it up.
you may need to be already logged into your Member Centre to view this, but you can find the open Ticket here
I've also popped my test results onto this post if you'd like to have a look.
23-06-2021 4:48 PM
23-06-2021 4:59 PM
