Fibre order still not active
FIXEDTopic Options
- My Order
- Re: Fibre order still not active
19-04-2016 12:10 AM
Hello...
I've put my order for fibre broadband on the 31st of March. The line was activated on the 1st, not that I have any use for it. After many tracker messages Plus.net was able to put an order that was supposed to activate on the 18th. It is 19th and still nothing!!
What's going on? Will I get my internet or should I cancel the order???
Fixed! Go to the fix.
Message 1 of 4
(1,625 Views)
3 REPLIES 3
19-04-2016 12:25 PM - edited 19-04-2016 12:43 PM
Hi Alex,
I'll get this checked out for you, and I'll update the thread shortly.
Are you able to get online now?
Matty
20-04-2016 9:32 AM
@MattyC wrote:
Hi Alex,
I'll get this checked out for you, and I'll update the thread shortly.Are you able to get online now?
Matty
Yes I am!!! Thanks a lot!!!
Alex
Message 3 of 4
(1,583 Views)
20-04-2016 11:39 AM
Spot on
Message 4 of 4
(1,572 Views)
- My Order
