Fibre broadband not yet active
HH
I ordered fibre broadband services on the 31st August 2017 and it was not until later that I was advised it would not be activated until the 27th September 2017, almost a month later. I have since requested whether there is any possibility of this date being brought forward and have been told it cannot be. My issue is that it seems to suggest to you initially online that it will take 14 days, when in fact this is the minimum time period, not how long it will actually take.
I understand that this date cannot be brought forward now, however I have already made payment for this month along with the set up fee and want to check that the monthly payment will be used from the date on which the service is activated not between the 31st August and the 27th September.
Thank you.
3 REPLIES 3
Gel
Aspiring Champion
Fixes: 29
Re: Fibre broadband not yet active
Mav
Fixes: 514
Moderator's note:
Moved to the most appropriate board: My Order.
Forum Moderator and Customer
Fixes: 1,599
Hi there.
Sorry about the delay with your order. It's due to engineer availability in your area.
That's estimated, however we'd advise the following in your welcome email:
* Sometimes, circumstances beyond our control may alter your switch date. We'll keep you informed of any changes
Your initial fee will essentially begin from the point your services activate.
I hope this helps clarify things
Anoush
