Fibre Upgrade how long.
janitor1999
I agreed just over two weeks ago, have had the email confirming price but nothing else. How long would it usually take. I have received the new router two weeks ago.
4 REPLIES 4
Fixes: 1,483
Re: Fibre Upgrade how long.
Moderators Note
This topic has been moved from Fibre to My Orders
abails0105
Fixes: 60
Hi @janitor1999, thanks for getting in touch.
I am sorry for the lack of communication there has been with your fibre modify order. It looks like your upgrade order has recently completed, I'd recommend, if you haven't already done so, setting up your router and you should be able to connect.
Let us know if you experience any issues.
 Alice Baillie
janitor1999
Thank you for your reply, the connection dropped this morning and was on fibre when it came back up.
HarryB
Fixes: 256
Glad to hear you're now on Fibre @janitor1999, thanks for letting us know.
 Harry Beesley
