Fibre Upgrade Activation Date?
rickw584
I was told that my fibre migration would take place on the 5th June, but I'm still on my ADSL service.
When will the cutover take place?
2 REPLIES 2
Fixes: 356
Re: Fibre Upgrade Activation Date?
@rickw584 It's likely that the 5th was the original estimated date and that it's been pushed back due to engineer availability. While you wait for an answer from Plusnet staff, you may want to see if your line has an open order on it. Use the BT Checker to see if there is one in place and if so, it will show the completion date. https://www.dslchecker.bt.com/adsl/adslchecker.welcome
NB you need to look in the text following the speed estimates, you should see something like 'there is an open order on the line , due to complete on.....'
abails0105
Fixes: 60
Hi @rickw584
Thanks for getting in contact. Apologies there has been no communication regarding your order. I have updated the open support ticket on the account for you and this can be viewed here: https://www.plus.net/wizard/?p=view_question&id=175589008
Let us know if you need any further assistance. -Alice
 Alice Baillie
