Fibre Speed after upgrade from adsl today
roger_sutherden
Hi
Getting 21MB download & 6MB upload.
Should it improve or is it all I can get
Roger
9 REPLIES 9
Mustrum
Fixes: 77
Re: Fibre Speed after upgrade from adsl today
What speeds are you expecting? What does the DSL Checker say you should bet getting?
roger_sutherden
dsl says impacted 35mb down   8.5mb up,
I was hoping for about  30mb down and 8mb up
I am about 300 yds from the cabinet if that helps
adamwalker
Fixes: 221
Hi Roger and I'm sorry for the poor start to your fibre upgrade!
Diagnostics are confirming a fault, we've got that reported to our suppliers and we should be able to update you further about that over the next few days.
 Adam Walker
roger_sutherden
Thank you for picking up the issue from my speedtest,
I thought I might have to raise a fault myself.
Hope BT sorts it out quickly.
Fixes: 1,600
I've just checked on your fault report Roger and I can see we've got an engineer appointment booked in.
Can you let us know how the visit goes?
roger_sutherden
Unfortuately they did not make today, openreach have rebooked for thursday am will give you an update after that.
Regards Roger
Fixes: 1,600
Sorry to hear the engineer didn't arrive yesterday Roger.
Fingers crossed it goes ahead then, let us know how it goes.
roger_sutherden
Hi Gandalf
BT engineer arrived changed me to copper back to cabinet, his test showed
40Mb down 10Mb up.  DSL on router shows the same.
Speedtest shows  37.55 down & 9.36 up over ethernet poweradaptors.
If it manages to stay close to this I will be a very happy customer.
Thank you for showing an interest in my problem its why I stay with plusnet.
Roger
Fixes: 1,600
I'm really glad to hear that Roger.
As I've said elsewhere, I love it when a plan comes together! Smiley
Let us know if you have any further issues or queries in the future.
