Fibre Install - Old BT Socket
Studio_Muppet
Hello! :smiley: I have my install date confirmed for Plusnet Fibre but have a few questions.
I've been told I'll need a new phone line as I'm switching from a Virgin Media cable only service. I spot a BT faceplate with socket next to my front door but it is a vintage LJU (poss 1980s?) certainly has a RJ11 socket so a modern phone plugs in fine (although line is dead).
So will the engineer that visits be able to use the wires connected to that old LJU socket for the install of the new fibre socket?  ...or will it be a case of running new cabling to the house?
Also will a BT engineer visit or contracted communications company (eg. Kelly)?
Cheers :thumbsup:
Tags (4)
4 REPLIES 4
Fixes: 321
Re: Fibre Install - Old BT Socket
Moderators Note
This topic has been moved from Fibre Broadband to My Order.
Customer and Forum Moderator. Windows 10 Firefox 69.0.3 (64-bit)
Life is tough enough without adding Linux into the mix.
Fixes: 284
Thanks for getting in touch @Studio_Muppet
Generally speaking, if there's an older BT socket there they may use that socket but update it to the latest NTE. If any new cabling needs installing then the engineer may just route it through to that socket but we won't know for certain until the day.
Having said that checking the notes on our supplier's systems appears to show that there's a spare underground pair available which they'll most likely use to install the line.
If you have any issues on the day or any further questions just let us know
 Matthew Wheeler
Studio_Muppet
Thanks for the information @MatthewWheeler very helpful :thumbsup:
As you say a lot will be depend on the engineer inspection on the day but I'll keep my fingers crossed that the original BT wiring can be used as I can tell that was dropped into the property back when it was built in 1981 so it is neatly running out of sight, must be cemented in underground. I even have a little brown manhole cover right outside the property embossed with the words "P O"  so who knows, this could conveniently be the telecoms connection point? (See attached)
Thanks again for your time. :smiley:
Fixes: 284
Thanks for getting back to us @Studio_Muppet.
If it's labelled PO then it'll be a duct box back from when Openreach was a sub-division of the Post Office hence the PO initials.
If I was a betting man then chances are this may be where the pair is so on the day the engineer will likely open it up to connect the line up.
 Matthew Wheeler
